I noticed before one ride I was down almost a quart of oil.I saw no leaks and filled it.I went for a couple rides over the next few months and I checked the oil and it was down almost another quart.
I ran it by the dealer and he said it had to be leaking or if driven in dusty conditions then maybe the rings were worn due to dusty air getting by the air filter.
On the pto side I had a intake boot leaking as detected by spraying brake clean around that area.
I did notice below the boot on the Mag was wet prior to doing any test with the break cleaner but it did not seam to leak or try to shut off when applying the brake cleaner the way the pto side would shut off when the cleaner was applied.
I did a compression test and had 180 on the pto side dry and 210 wet.
" " 165 on the mag side dry and 180 wet.
I did a leak down test and had 25 % loss on pto side.
" " 65 % loss on the mag side.
I could hear most of the leakage out the filler cap and dipstick hole .I repeated the leak down test on the bench once I removed the motor. The leak down results were similar and I could hear some leakage out the intake valves and if I put some brake cleaner in on top of the valves from the intake I could see it bubbling from the air being applied to the tester/ cylinder .Leak downs were done at TDC.
I know for sure it was leaking around one boot but ironically that side has the best numbers.I could not see any bubbles in the rad when i did the tests in while the motor was in the bike nor hear any air coming from the water fitting on the block or coming out the water hose nipple on the water pump when I repeated the leakdown test on the bench.
I have an idea whet is going on but wanted to see what you folks had to say about my numbers.
