New Crew 2015 camber out on front right top 1 1/12 in' inward took it to dealer they said that was normal anyone have experience with this?
Right side is out 1 1/2" and the left side isn't? And your dealer says that's normal! Time to find a new dealer!
Curious what your dealer is calling normal, so can you take a picture and post it?
Super Moderator
The Rangers have a few degrees of negative camber built into the suspension geometry, this helps with stability while driving.
There are a couple of things that accentuate this, worn upper and lower ball joints, worn A arm bushings, bad wheel bearings and possibly a broken spring or shock.
Being this is a new machine, I would not think any of these parts would be worn out or broken.
As stated above, please post some pics.
