ENGINE & DRIVETRAIN
SUSPENSION
BRAKES
TIRES / WHEELS
DIMENSIONS
FEATURES
Engine Type | Single 48-Volt, High-Efficiency, AC-Induction Motori |
Transmission/Final Drive | Direct Drive With Low-Noise Gears |
Drive System Type | On-Demand True AWD/2WD/ VersaTrac Turf Mode |
Engine Braking System (EBS) | Not Equipped |
Active Descent Control | Not Equipped |
Front Suspension | MacPherson Strut 9" (22.9 cm) Traveli |
Rear Suspension | Dual A-Arm, IRS 9" (22.9 cm) Travel |
Front/Rear Brakes | 4-Wheel Hydraulic Disc with Dual-Bore Front and Rear Calipers |
Parking Brake | Hand-Actuated |
Front Tires | 25 x 9-12; Carlisle |
Rear Tires | 25 x 9-12; Carlisle |
Wheels | Stamped Steel |
Bed Box Dimensions (L x W x H) | 32 x 42 x 11.5" (81 x 107 x 29 cm) |
Front/Rear Rack or Box Capacity | N.A./500 lb (226.8 kg) |
Ground Clearance | 10" (25.4 cm) |
Overall Vehicle Size (L x W x H) | 110 x 58.0 x 73 in. (279x 147 x 185 cm) |
Payload Capacity | 1,000 lb (453.6 kg) |
Person Capacity | 2 |
Wheelbase | 72" (182.9 cm) |
Estimated Dry Weight (pounds/kg) | 1,726 lb (783 kg) |
Cargo System | Lock & Ride |
Color / Graphics | Avalanche Gray |
Hitch Towing Rating | 1500 lb (680.4 kg) |
Hitch Type | Standard/2" Receiver |
Instrumentation | Digital Hour Meter, Mode Indicator, DC Outlet, Hi-Temp Light, Change Cycle Indicator, Battery Life Indicator |
Lighting | 50W Headlight, LED Tail |
