2017 crew seemed like it was not pulling as it should almost like the 4wd was disengaged. Front wheels did turn when I jacked up the rear, but in turf mode I noticed both rear wheels turning. Shouldn't just the right rear turn in turf mode?
Sent from my SM-G960U using Tapatalk
2015 Polaris ranger 570 XP
In Turf Mode, the wheel with the least resistance will spin. If both have equal resistance both will pull/rotate. If you perform your test again and hold one wheel the opposite wheel will spin. With both wheels on the ground both will pull until one wheel reaches a place where there is little traction at which time that wheel will spin until it regains traction or the vehicle comes to a stop with that wheel spinning.
Reactions: blindman75
