On a recent trip up the mountain, I found that my Ranger had locked into 4wd (good news, since I could still get back home). At home, I noticed the lights on my 4wd indicator weren't working, which lead me to the fuse box. The 20 amp light fuse had popped, so I replaced it. Short drive around the neighborhood, same thing. So I started taking things apart to look for a worn wire, something grounding the circuit. No dice. I started disconnecting things, even the headlights, and the issue still occurs after 5 min or so of driving. What else is on that circuit that could be causing this issue?
Note - I had a light bar, but disconnected it to ensure it wasn't the problem to begin with.
