I don't know how to bleed the fuel system, but I'd try that. For some, you crack a line, for others, you turn the key off and on, and some do it automatically. Look up how to do it on the Ranger.
Yes, I have bleed the fuel system per the service manual. No impact on the issue.I don't know how to bleed the fuel system, but I'd try that. For some, you crack a line, for others, you turn the key off and on, and some do it automatically. Look up how to do it on the Ranger.
I have also pulled the fuel return line going into the fuel tank and there is fuel returning to the tank. So it would appear that the fuel pump and solenoid are working.Yes, I have bleed the fuel system per the service manual. No impact on the issue.
The finger method will not give you any information on whether or not low compression is your culprit. You'll need a diesel compression tester due to your cylinder compression being close to 500 psi. Compression of 100 psi would blow your finger off of the hole but would not let that diesel start.Manual says that is also where to test compression. Just held my finger over the holes and cranked....blew my finger off of all three
Still fighting this. Here is the current situation. The timing was off. So that has been corrected. It will still not start on it's own. It will start with some starter fluild help....then once that burns off it will run off the fuel and idle. The idle is smooth and it sounds like it should. However it is blowing white smoke like crazy...smells like unburnt diesel. When I give it throttle it struggles and can't get up to speed. Compression tested fine. I am having a hard time finding someone that can test the injectors. I left it running for 30 minutes at an idle with some Seafoam.
if you are throwing white smoke it says fuel is not burning or water in the cylinder. If it’s a 18 you have the Koehler engine so could be the timing of the fuel injectors is out of time. Remember each injector has its own built in pump. I fought mine for over a year until I finally found out how to time the injector.Still fighting this. Here is the current situation. The timing was off. So that has been corrected. It will still not start on it's own. It will start with some starter fluild help....then once that burns off it will run off the fuel and idle. The idle is smooth and it sounds like it should. However it is blowing white smoke like crazy...smells like unburnt diesel. When I give it throttle it struggles and can't get up to speed. Compression tested fine. I am having a hard time finding someone that can test the injectors. I left it running for 30 minutes at an idle with some Seafoam.
Start out timing the injectors by seeing three threads where the nut is. That’s a good starting point, then turn one at a time 1/4 turn till it’s running correct. a little bit changes it a lot. 1/2 turn changes the timing 5 degreesif you are throwing white smoke it says fuel is not burning or water in the cylinder. If it’s a 18 you have the Koehler engine so could be the timing of the fuel injectors is out of time. Remember each injector has its own built in pump. I fought mine for over a year until I finally found out how to time the injector.
