241 - 253 of 253 Posts
Mine definitely gets worse after use and heating up good. I dropped it off for service this morning and to have it checked out. I'm a little nervous about what they're gonna find.
Hope it's nothing major!
Gotcha. Could be an axle clicking....
Yesterday after doing a pretty hard run with mine I noticed a clicking sound coming from my rear end after I shut it down and it was sitting....weird.
That is most likely your exhaust system making this sound. It's just the metal cooling off after getting hot from a full throttle run.
And this is going to get worse as the flex/carrier bearing goes south.
have quite a bit of play in my carrier bearing and the CV joint area where the roll pin go's into the Differential input shaft
Did you hear back from the dealer? Mine did the same thing. I changed the front diff fluid and it improved it quite a bit.
Definitely NOT what it was since it was a ratcheting noise while being driven on the left side of the machine. Dealer took the whole rear suspension apart. Said it seemed like the control arms were binding some. They greased everything up with lithium or silicone and put it back together. Seems to have "fixed" it for now.
Ran a search, but didn't really see anything...My machine has developed a "ratcheting" or clicking sound in the rear end. I've read the comments about the brake calipers possibly being loose and rattling. That ain't it. Sound more like a differential issue. Anyone else have this happen?
I had this too. It sounded like it was coming from the right rear if you're sitting in the driver's seat. I ended up putting new wheel bearings all the way around and adding 4 new Rhino 2.0 axles. I tow a small trailer loaded with corn/protein for deer feeders quite a bit. I also drive in turf mode most of the time. I suspected that with all of the torque on the single stock axle(right rear), it may have worn out causing the ratcheting sound. Once I had the axles out it was obvious the bearings needed to be replaced too.
My main complaint so far is the jerk when trying to ease forward or back from a stop.
If you kept tabs on clutch discussions there seems to be plenty with alignment issues. Hunter got one with the issue before he got it home
Mine snaps pretty hard in forward but especially in reverse.
Put on a lot of stops and starts 3rd through the 7th while using the Ranger to take products out to the field for setup of fireworks show. Went through 2/3 tank. Backing up to truck and running to various spots. Was almost as smooth as the Duraclutch equipped 900xp. The improvement in suspension is making the owner of the 900xp think hard on upgradeing.
