I have a 2018 ranger 900. It sputtered and died and will not restart. It has 58.5 psi at the fuel rail. It also has power to the injectors. If given starting fluid it will run until out of ether. I'm at wits end. Help.
Hey Steve, that makes no sense that you have the proper fuel pressure and it won't start but will start and run on ether UNLESS............ the fuel is no good ......water in it.. Almost has to be that. Check for fouled plugs at this stage.
