It’s a hydraulic western plowI would start with the winch and make sure it isn’t drawing excessive amps. Then check the voltage regulator. Then the charging system. Sounds like voltage reg.
He said he changed the battery.Put a full size battery in and you will have no more problems , I put a Optima under the seat six years ago for the winch and have no problems since ..
He changed battery but didn't go big enough . Bigger is better !He said he changed the battery.
When they first added the pulse bar. Some were having the same problem with their northstars and polaris brand plows. When wired directly to the battery instead of the pulse bar, everything worked as it should. Dont know the why, just remember the problem.Don't have a plow (no need in the south) but my 2018 also dies if you winch hard enough to stall the winch motor . I have done some testing and apparently the battery voltage doesn't have to drop much to make the engine die. It doesn't matter if it is wired directly to the battery or not. The only solution is a bigger battery or 2 batteries.
If your winch motor is starved for sufficient current, wiring directly to the battery could help that problem, but if the battery voltage is dropping too low at the battery it is a different issue. I suppose if the wiring to the winch motor is too small, it might be possible to drop the voltage enough at the winch motor to cause the motor to draw excessive current. I only had any problem with the engine dying when the winch was completely stalled. It certainly would be better to wire directly to the battery anyway.When they first added the pulse bar. Some were having the same problem with their northstars and polaris brand plows. When wired directly to the battery instead of the pulse bar, everything worked as it should. Dont know the why, just remember the problem.
It is wired to batteryI have the Oddessey 1200 and a hydro plow with a 2 hp motor, no issues in 3 seasons. Maybe you have a motor that is overdrawing. The motor should be wired directly to the battery from the motor relay.
The name plate for plow?Those power packs electric over hydrolic tak some big power! Post a pic of the nameplate.
YesDid you wire directly to the battery?
If this unit has a Polaris 900 or 1000 engine we make an alternator that will run anything you put on it, [email protected]I installed a v plow on my North Star and when I use plow voltage drops to 11 and most of the time engine dies just put a oddessey 1200 battery in but didn’t help much
You make one for 2019 northstar 1000If this unit has a Polaris 900 or 1000 engine we make an alternator that will run anything you put on it, [email protected]
Winch Motors Draw a Lot.I installed a v plow on my North Star and when I use plow voltage drops to 11 and most of the time engine dies just put a oddessey 1200 battery in but didn’t help much
