1 - 3 of 3 Posts
Hey all. As the title says. I've got a ranger 570 that dies after about an hour of driving. Fuel pressure drops and then it shuts off. Strange thing is, is that it fires right back up afterwards like nothing happened. After shutting off once and restarting it will shut off a lot quicker than the first time. Bad fuel pump? Or am I looking at some other issue?
2015 Polaris ranger 570 XP
Might be an ECU going bad, a bad coil. You state it fires right back up after shutting down....do you mean immediately or after a couple of minutes. Check your ignition switch cor continuity and wiring connections for corrosion/dirt/good connections.
Fires back up immediately. So far it looks like it might've been a dirty fuel filter somehow. Cleaned it as best I could to test if it was that and sure enough I drove for over an hour and it ran fine.
To be fair the fuel pump did sound like it starved of fuel as the engine shut off before I cleaned the filter
1 - 3 of 3 Posts
