1 - 7 of 7 Posts
Is there a reverse beeper wire already on a 2020 Polaris Ranger 570 Midsize with EPS?
i am wanting to hook up reverse lights to come on when I put mine in reverse so I don’t have to wire in a switch.
I believe that was deleted in a previous year. My 2018 I had to add this Amazon.com: Polaris 2880631 Reverse Beeper: Automotive. I'm not 100% sure if that is what you need, but pretty sure you do not have an existing wire. I just tapped off the beeper with lights. I ran a switch to shut off the beeper when not needed. Around campgrounds, I enjoy having the annoying beeper.
Yes the wiring harness connects to the ECM to provide the reverse switch circuit. Replace the beeper with a relay. Connect power, ground and your lights to the relay. Seal the relay and all the connections to prevent water and moisture from causing shorts.
There are installation instructions with the reverse beeper wiring harness. I did mine on my 2015 midsize about 5 years ago. If you search here you might find my old posts on the subject
1 - 7 of 7 Posts
