2008 700xp Just changed out the TPS SEEMS to run better??????? Also went ahead an replaced the 8 year old original battery. After hooking everything back up I'm now getting this code????? Unhooked the battery to try and clear it No good.. Any ideas about why??? I though maybe I broke a wire but the dash shows the correct gear that I'm in. Is there more wires that tell the ecu what gear Its in???? Will pull the harness again tomorrow to see if I did something there
