1 - 7 of 7 Posts
I have a 2015 XP900 Crew and went to install the doors and the bottom Hinges don't look right. Anyone know if there is a different hinge for the crew vs the Std cab XP900?
Im pretty sure i read that power window doors DO NOT fit crews.....you might have to modify the hinges???
Reactions: 10spoke
If you only bought the front doors you are screwed! With the crew you need to put the rear door hinges on the front and the front door hinges on the rear. That's just how they do it. I initially bought fronts and then realized they couldn't be installed without buying the rear doors.
Why would you only buy front doors for a crew?
Discussion Starter · #6 ·
seems like the hinge pattern on the power window front doors are slightly different then the hinged /fixed front doors.
may have to modify.
· Administrator
may have to modify.
The hinges are different, also the power window doors are wider/thicker than the fixed window.
Can you post a pic of your issue.
I'm not certain why they will not fit, both rear cage assemblies are dimensionally the same, so I am curious why polaris states that the power window doors do not fit the crew. I know there is a reason, I'm unsure what it is.
1 - 7 of 7 Posts
