1 - 7 of 7 Posts
Anyone running 29.5" outlaws on their ranger?
I am looking at purchasing a set of 29.5" outlaws and I am wondering if I they would fit with a 3" lift and wheel spacers?
I don't really want to buy arched a-arms if I can help it... I don't mind if they rub a bit at full turn.... The tires would only be used a week a year for moose hunting and maybe couple atv rides which is why I would like to avoid the a arms. I already have the lift.
The tires are also mounted on ranger 800 aluminum wheels so I will have to get splines nuts as well to install them..
Thanks, Shane
I've got fwd arched arms with 2" lift built in and I clear 29.5 terms.
Reactions: shane019
I usually try not to weigh in on threads when I cannot directly answer someone's question, but I've got to throw my 2 pennies in here. It sounds like maybe you're getting a good deal on the OL's so you're trying to make it work. But it looks like you would be better off with a different set up. If the only use would be one week out the year for hunting and a couple of rides I'm thinking you could get a good set of 28" tires that would serve all of your purposes. What set up are you currently running?
I put mamba lites on that measured 27.5" no lift. they do not rub but so close, the mud or dust rubs away so close I wouldn't go any bigger. I read a lot before I put them on and it sounds like 28" rubs a little. This is with no lift. When I was reading the straight lift doesn't help much for tire clearance without the arched arms. That said I also read if you take a heat gun and basketball to the front wheel tubs 30s will fit a stock machine. Good luck tell us how it works out.
Discussion Starter · #7 ·
Thanks for the replys.....
Texas is right I found a good deal on OL so I want to try make them work if possible as cheap as possible... Superatv has forward arms for 250 only prob is our dollar is the shits right now so would cost a fortune by time I factor in exchange and shopping...
I ran 28" silverbacks without the lift with no rubbing...
I am currently running 26" big horns but they don't cut it for the bog up here moose hunting...
I have ordered spline nuts so I can mount the rims.. I will see if I can find a buddy with 1.5" spacers to mount them and see if they will work.
Thanks Shane
1 - 7 of 7 Posts
