I'm in the process of installing the backwoods armor high clearance arms with the 2 inch lift built in on my ranger 900. I like the bighorn tires. I'm torn between the 28 and 29 inch ones. Will I notice big power loss with the 29s?? Like so bad I'll need a clutch kit ? Or would y'all stick to the 28s
You've got a 900, right? If it were mine, I'd go with the 29's. There's always improvement to be found with adding a clutch kit, but the power of the 900 will not struggle to turn 29's on stock clutching until you have time and cash to upgrade the clutch.
I have the same lift and arms and have no problem turning over 29.5 terminators with stock clutching.
Ok great thanks guys. Yes it's a 900
I have the 570 full size and run 31's with zero issues from power loss or clutch trouble.
