1 - 11 of 11 Posts
What about running shocks on outter holes?
Mine did the same thing, just put a three inch lift on and no more rubbing. My crew actually rides better.
I typically discourage lifts of more than 2", as they are pretty hard on stock CV's. A 2" lift or stiffer springs (the weight of the Crew is the culprit) will keep it from rubbing.
I wanted a 2 inch, but I read really good reviews on the super atv 3 inch lift. I think my stock axles are going to hold up fine, it's all up to your right foot...
I like to climb over dirt hills and logs will this cause them to break even if im carefully. this would be after the 3" lift satv
Just take it easy on the throttle....especially in low range and when you have the wheels turned sharply in AWD.
1 - 11 of 11 Posts
