So after my most recent troubleshooting, I swapped out the complete throttlebody fuel pump, fuel injector, crank position sensor, and finally ECU. fuel pressure was low and I think it is running slightly better, but still wants to die cold. Spits and sputters. so I finally broke down and sent it to the dealership. They are going to try to re-flash the ECU. But the mechanic is fairly certain that the valve guides are gone in the cylinder head says he’s seen it multiple times with guys running 91 octane fuel, where it will burn the ex valve guide out of the head . And of course, after trying to swap, ECUs, the donor vehicle ECU failed on me about an hour later so if anybody has a 570 ECU laying around I would love to buy it off you.!
