1 - 3 of 3 Posts
Punisher , It has a slightly different part number so..............I am not sure...
i been doing research on this. I wanted the rear differential gear out of it because it’s a solid gear and doesn’t have turf mode. The chains are the exact part number but the seals are different and so are the bearings where the axle splines in, so I’m thinking that’s the only difference. Wasn’t wanting to have to build some hybrid axles To make it work. If you find out that isn’t the case and it will work with ranger axles I’d love to know so i can put mine Together that way
1 - 3 of 3 Posts
