Status
Not open for further replies.
1 - 9 of 9 Posts
This Ranger I have just won’t start. Cranks put will not start. Took it to dealer in Salida, CA. On Jan 21. They worked on it for 75 days and cannot fix it. While working with people in Minn and replacing, checking and videoing everything, ( they said) they cannot get it to start. They are baffled to the point they said come and get it, we don’t know what the problem is!!!!
Any help would be appreciated!!!
· Administrator
OG, going to need a lot more info. We can't do much with, "my Ranger won't start, why?"
Hmmmmmm, maybe out of gas ? 🏆
· Administrator
Griz, did it have spark ? Did it have fuel delivery to the cylinders ? Wet spark plugs ? backfire ? anything ?
Discussion Starter · #6 ·
Well took a vague short cut however to spell it out;
Replaced ECU after reprogramming new one, replaced plugs, videoed fuel injectors, replaced fuel, did compression check, traced all wires in harness and applied diaectric grease to connections, replaced battery and maintained contacts with people in Minnesota relaying test results and getting instructions.
No one could diagnose issue which is strange if you ask me…..
· Administrator
So ............... Griz, did it have spark ? Did it have fuel delivery to the cylinders ? Wet spark plugs ? backfire ? anything?
Here's your chance to speak before I close out this gem.
Discussion Starter · #8 ·
Yes, had spark and a video was provided for Minn Rep showing fuel injectors performing correctly . No backfiring and as far as spark I personally don’t know.
Thanks for your questions. Now you can close out this mysterious gem.
· Administrator
"Yes, had spark " >>>>>>>>> "as far as spark I personally don’t know. "
Oh O.K. Griz, I gotcha ;)
1 - 9 of 9 Posts
Status
