So my 14 crew 800 came with a larger battery than the older models and it's located under the rear seat drivers side. Not sure if the battery is bad or if I should just ignore the low battery prompt, but at night all I will have on is the headlights and a smal 12" lightbar. Within a few minutes and running the machine, the low battery indicator will come on.
i would eventually like to replace that lightbar with a 30" bar but will need more juice to power it. Would I be okay with a good replacement battery or would I be better off with a dual battery setup under the back seat?
What at are yall running to power all of your light bars and accessories?
