Has anyone added the drivers side adjustable seat slide option ? My girl friend at 5'1" +- drives my ranger occasionally and always mentions how much better it would be if it adjusted.
I have the adjustable seat, I did not add it.Has anyone added the drivers side adjustable seat slide option ? My girl friend at 5'1" +- drives my ranger occasionally and always mentions how much better it would be if it adjusted.
Good find, I just overlooked it. It is still available in kit form for $169.99.polaris part #-2879272 $169.99 2014 polaris accessory book
That would be correct.My seat back is solid. My seat bottom is split , unlatches and flips up. To make it work properly. I'd guess I'd have to buy the split seat back. I did see the seat adjuster on Amazon and a sidexside site for the rzr...but not the Ranger.
You're probably not going to be able to adjust it when it's sitting on the ground, if it is anything like my seat it takes some force. Reinstall it, move the lever on the front when you're seated in it and then while holding the lever try to shift forward and it should move.My 2017 XP 900 Ranger came with a slider seat that I absolutely cannot get to slide. I pulled the seat out have it sitting on my shop floor. The catch lever doesn't seem to engage in anything. Can anyone help?
