Here is what I got from Royal Purple
Polaris, though makers of excellent ATVs and UTVs, provides ambiguous and occasionally changing fluid recommendations for their vehicles. Our recommendations are based on what we could determine based on the scant information available on the Polaris lubricants, and field use by many of our customers. If warranty compliance is a still a serious concern for you on your Polaris ATV/UTV, we recommended sticking to the OEM fluid. Listed below is our recommended Royal Purple product for replacing the Polaris AGL Synthetic Gearcase Lube.
AGL Synthetic Gearcase Lube: Royal Purple Synchromax (part #01512, quart bottle)
Judging by the MSDS for the AGL Gearcase Lube, it is a light viscosity fluid (very similar to an automatic transmission fluid). I have seen reference to people using a Dexron III fluid, but it is not optimal. Our Synchromax fluid is what we generally recommend for gearboxes that specify an ATF-like fluid, as it is of the appropriate viscosity, but contains additional additives that protect gear faces and sprockets and chains found in manual transmissions and transfer cases.
Thank you for choosing Royal Purple, and have a great day!
Best Regards,
Cody Bartkowiak
Automotive, Technical Support
p 281 354 8600 f 281 354 7600
e
[email protected]
One Royal Purple Lane Porter, TX 77365
cid:
[email protected] cid:
[email protected]
