1 - 7 of 7 Posts
deadlytedly and hiatt65 are both running it. It does a good job of keeping the voltage above 14 volts.
10-4.... i think i need it bad!!... i've got a radio and all... running a light bar... but battery light flashes, have to turn it off regularly....not to mention... the constant surging.... and flickering of lights.... if my thoughts are correct.... this will correct these problems? yeh?
I had the "Magic Power Box" on my rhino. All it did for the rhino was to run the battery down. The rhino was at my cabin so I only drove it on weekends...and every weekend after I installed it, the battery would be dead. Apparently it always had a small power draw, even with the key off, so unless you started the rhino every day or so it would kill the battery. Numerous other rhino owners report the same problem. I returned the one I bought. Maybe the ranger version is different/improved. Good luck, Mike
I have had mine for close to a year without any problems.
1 - 7 of 7 Posts
