Super Moderator
Hi all - just came across this. What are your thoughts? :)
B-L Tech Hub Hornet
Article in this month's issue of UTV Sports: https://www.utvsportsmag.com/issues/june-2018/?utm_source=Vol5Issue6:+#1&utm_campaign=Vol5Issue6:+#1&utm_medium=email
Page 40
I remember seeing these awhile back, then remembered reading your post.
Anyway, I have purchased a couple of these and will be installing them, when my new Hub assemblies come in.
I have taken the measurements and tested the material.
I will say that the machine work is very good, the tolerances are tight.
I like the Concept and Design.
I purchased them from Optimum OFFroad, they are the Exclusive Dealer.
2C92F5A6-79E2-4812-BD71-A1C89FE60C55.jpeg B44ABD40-F3A8-4455-8F77-0A83B4AE0F35.jpeg
You need one for each side ? And how difficult is it to remove the factory sleeve and install the new one ?
Super Moderator
Willie, you only need to purchase 1 per Front Gear Case. ( both pieces in the lower pic are included)
Its not hard to remove the OEM Hub, and these are not hard to install.
But you do have to disassemble the Front End and Remove the Front Gear Case.
I like the idea, but the price IMO is a little high.
The pic makes them look bigger, but they are only 1 5/16 in diameter.
How did you get that OEM bushing that is press in, out of the hub?
