When I changed the drive belt, I noticed the belt was rubbing on the clutch cover next to the air outlet hose fitting. I contributed this to a worn belt. After installing an OEM belt, the noise returned but only when the transmission is in neutral, which I assume, is the belt once again rubbing on the housing. Any suggestions as to why the belt is rubbing on the clutch cover.
2009 Ranger 700XP
2009 Ranger 700XP
