Which year and machine do you have? That will determine how much lift you need to clear 27" tires.Would like to know what 2 or 3 inch lifts you'r running just for some extra groung clearance and some 27x12 tires without causing any cv problems?????
Ive been looking at the HL 4" for my '15 900..are you still running stock axles? what kind of angles do you have on the front and rear?Both Rangers have the HL 4" mine with 31" Outlaws and the other with 28" tires.
Jerry i have 13 900xp, just would like some better clearance and 1 inch taller tires, ia'm not very hard on my machines anymore but will be plowing and realy just mainly put around to hunting spots and easy trail rides!!!!Which year and machine do you have? That will determine how much lift you need to clear 27" tires.
I generally discourage lifts of more than 2" because that approaches the "reasonable" limits of the stock CV's. Of course, a lot of that is determined by how you drive (getting aggressive with the skinny pedal has a tendency to break a lot of things).
Are you running the same size wheels/tires all the way around or wider in the back and narrow up front?Not many running that lift around here and I know that the rears usually have a little steeper angles than the front..I'm not planning on running a tire quite as big as yours but want that additional clearance and like the stance. I ran HL 3" on my crew and had no issues..
