Brake pressure switch
11K views 6 replies 2 participants last post by  RJ
Could someone tell me where the brake pressure switch is on a 2012 xp 800?
Brake lights are flickering and staying on after the machine is shut off. I can pump the brakes real quick and they will go out for a bit but sometimes still flicker.
Figured cruddy connection or bleed the brakes. Hasn't lost any pedal that I can tell?
Thanks.
#3 ·
Thanks Mike.
That may be a bewatch to get to. I need metric sized fingers.
Reactions: mtimesplitter167
#5 ·
Not yet...but figured that's what's going to have to happen after seeing where the switch is. Haven't looked at it real close yet. Do you know if its fastened from the inside or outside?
Thanks again.
#7 ·
Awesome!
Thank you sir. I owe ya a cold one.
