ok lets start off by getting the basics out of the way...
JUNGLEMANS LIST: When asking for assistance I suggest providing the following information:
Year/Model of the Vehicle -2013 Polaris Ranger 800XP Special Edition W/ EFI
Is vehicle new to current owner or been a one owner vehicle - Used, i just got it
Description of Problem- see detailed descriptions below
History of previous problems that might be related - the PRV dowel got stuck, took out the camshaft, PO tried to repair it and never finished
How old is the fuel/Ethanol or Non Ethanol - gas was low, i put good 91 octane in it, pressure is at 58PSI
How long since vehicle was last used and ran normally - No clue, i have never seen it long term run
When problem began (Example: After going through deep water or After filling Fuel Tank or after sitting unused for a year)
Did problem begin after Recent Modification or Accessory Addition -see description below, but yes aftertop end rebuild, new oil pump,2x 8mm PRV repair
Under what Conditions does Problem Occur - when it gets to operating temp? or after running for 3-5 minutes
Odors, Unusual Noises, Changes in "Feel" of Vehicle while Riding - smell of gasoline
Any repairs already attempted and the Outcome (Example: Cleaned Battery Terminals, no change) -see description below
Results of any Tests already performed (Compression, Spark, Voltage, Battery Condition etc.) - see descriptions below
8,000 (ish) miles
Fuel Pressure : 55-59 PSI ( cold and at idle)
Miles that I have personally rode it : 1/2 mile TOPS....
Background: I traded this unit NON RUNNING for a Mustang skidloader, the guy that i traded it to purchased it (supposedly) running from a farmer but it burned oil, so he did a top end rebuild on it, he got the REV6 kit W/ 80.0 mm pistions, new hydraulic lifters and a replacement cam, he did everything EXCEPT replace the cam... still didnt run. then traded it to me...
Repair #1 So when i started on it i found that the PRV dowel was completely locked in, it wouldnt budge, so i replaced the oil pump/water pump and seals, removed the dowel and replaced the dowel with the 2x 8mm ball bearing solution. PS. this was all done with the motor inside the unit! I have yet to pull the motor out...
Repair #2 I then soon realized that i was having a hell of a time turning over the motor... long story short, i had to tear apart the whole side of the motor agian and replace the cam that the previous owner did not replace....now its back together!
Repair/installation #3 I installed a water type heater that runs off the coolant, I bought this with plans of taking it up to the lake ice fishing, and i bought the kit off ebay used. it seems to be working just fine, i dont know if it matters BUT i want to list everything i did to it so im not leaving anything out....
NOW HERE IS THE PROBLEM/PROBLEMS
Day #1 I started the unit, let it idle, and then drove around me neighborhood for a couple minutes... i did NOT go over 20 mph. it acted like everything was perfect, idles smooth, runs fine, ect.
Day #2 i thought i should drive to the car wash and clean up the belly pan from the oil and antifreeze from repairs 1,2,and 3. So i turn on the ranger, it starts fine, and shifts into drive just fine, I drive 4 blocks ( about 150 degrees is what my gauge is showing for temp) and it starts to sputter, i give it a little gas and it comes out of it...for a second... then it continually gets worse... to the point where i turn around and start heading back home, i slow down for an intersection and i am unable to get it out of its "spit and sputter fit" so is just creeps along until it finally dies. I push it as far as i can but eventually have to get towed back to the house. the unit would NOT start, if i hold the gas pedal to the floor it acts like it is trying to start, but it also acts like it is backfiring out of the intake.
The next day, after cranking it over a bunch and trying to get it to run to no avail i installed a new battery because my battery tender kept running low... and the old battery was junk
Repair #4 I installed a brand new battery to isolate any battery issues
I installed a fuel pressure sensor onto the BACK side of the fuel rail were the test hose is located (PTO SIDE), to confirm pressure. when I turn the key on it SLAMS to 58 psi, it does drop a bit once the pump quits, but (when its running, because I left it on) it stays STEADY at 58 PSI.
I then pulled injectors, i held them into the rail and cycled the key, it is DRY as a bone.... no dripping that i can see, and i held a paper towel under it cycled a couple more times with no difference, the paper towel was dry also ( so it wasnt just me visually looking at it, it actually was not dripping. THEN I turned over the motor and watched for injector spray, it was even and a fine mist, exactly how they should be working IMO.
I checked spark next, I found that i had spark on the PTO ( Drivers) side and the plug was dry ( but had burnt oil on it), however on the MAG (passenger) side i was NOT getting spark (and the plug was oil fouled). the next day I replaced BOTH plugs, and it started right up. I thought i was a genius!...
I hopped in the unit and took off down the block, very conservatively i planned my route just in case it decided to fail again... and just like before it let me get about 4-5 blocks ( around 160 degrees in temp) away from home and it started to spit and sputter.... i limped it (downhill) ALMOST all the way home ( MAX of 5MPH) but it finally died out on me 1/2 block away from my house (which the last 1/2 is uphill... basically on a hard load the motor couldn't overcome it). Got towed home.
I pushed it into the garage, and just like last time it will crank and act like it is backfiring thought the intake? almost like my timing is off?? I removed the TMAP sensor to make sure it was clean, and for the heck of it i tried to turn it over... it popped off for a second AND it shot flames out through the TMAP hole.... So in my brain it is firing on the intake stroke? or atleast then the intake valve is open????
The next day i started looking at it again. Motor is cold. Still no start. 5:30 AM
I turned my head to timing... I evaluated the low hanging fruit first, i removed the camshaft position sensor & visually inspected the sensor itself, all looked good, i then looked into the wiring from the sensor to where it enters into the main harness ( about 12" of visible wire). There was no cuts, rubbing of wires, or what i could see as bad connector/connections. The only part i saw was that the heat sleeve that the wires sit inside had at one point in time got hot enough to melt and make it oblonged, it was exactly where the lower radiator hose sits... so im assuming it got hot from that hose. i wrapped the sleeve in electrical tape and reinstalled the sensor, being careful to not let it sit on the coolant hose.
I then evaluated the Crankshaft position sensor. I removed it, there was little crud, i wiped it off with my finger and reinserted it into the cover. I then inspected wiring, and visually the wires seem to not be broken, wore, or rubbed through in any way, i unplugged the connector and confirmed it seated well into its female counterpart.. pulled wires from both sides with the "5lb pull test" and all the connectors stayed in place.
I went to work and discussed the situation with a guy, there was no way my timing was internal if it starts & runs fine and then stops...he asked me to check the flywheel Woodruff Key for the possibility of a sheared key that is making my crankshaft sensor signal screwed up. I pulled the cover when I got home, and confirmed the key was not sheared. It was in tact and in good shape. I reinstalled the flywheel, and the cover, double checked the wiring on the CPS and for the heck of it I tried to start it, it spit and sputtered for a couple seconds, i held the gas pedal about 1/2 way out and it started to fire lightly.....
A couple more seconds and i was able to keep it running with my foot on the gas and no starter. i was "babying" it for another 20 seconds or so until i got brave enough to let off the gas completely and to my amazement it stayed running! I was astounded!
I did all my "quick checks" that I was unable to do while the motor wasnt running, i first confirmed fuel pressure 58PSI PERFECT,
Then I wiggle tested the injector wires ( specifically on the plug at the injector) to confirm no broken wires INSIDE the connector itself due to wiggling while driving/ idling, and it did not drop a cylinder
Then i wiggled/ moved spark plug wires all the way to the coil, no changes, im just waiting for a cylinder to stop firing and i cant make it drop!
I wiggled the crank AND the camshaft sensor wires, no changes
I wiggle the main harness, and the throttle position wires, no changes, nothing i wiggle will make the motor start to missfire.
I check fuel pressure again 58... i rev it up at idle, it drops a hair down to 55psi but IMMEDIATLY comes back up to 57-58ish.
I go back to the sensors ( crank and Cam) and i "tap" the sensors while it is running, trying to get something to fail... nothing.
I then notice that i have a oil leak, but not out of a seal, this oil is coming out the top of the dipstick tube?????
I disconnect the lock to the dipstick and pull it out slightly...and oil starts to spray out the top of the tube with light pressure... my buddy who is sitting there with me says that i have a LOT of crankcase pressure and recommends we stop the engine and do a compression test. we pull both spark plug wires and the MAG plug, test compression and i get 80PSI!? HOWEVER we reinsert that plug and remove the PTO plug, and i get the same 80 PSI???? IMPOSSIBLE that that motor is running on 80psi.. my plugs were both oil fouled...
My buddy says that he thinks the previous owner installed the new top end improperly and the rings are probly cracked, so we stopped for the night and i figured i would start looking for a ring kit in the morning... HOWEVER then a different friend of mine texted and asked how the process was going so I ran everything past him and he said we were wrong, he said that the rings had not had a chance to break in yet and that i need to go run the motor hard to break in the rings, that once the rings are broke in i will have great compression and that his ranger that he rebuilt had the SAME issue with compression/blowing oil out the dipstick tube until he got his rings wore in.
This morning i took a chance and thought "what the hell" I was going to see IF my motor would get above 160 degrees ( as i have yet to see it actually reach operating temp). I turned it over and it started, i ran it at idle and just let it sit there. I figured 2 things, #1 i would have a less likely situation of wiggling (due to the road or wind) if its just sitting there idling, and #2 if it doesnt get above 160 and die i would then have a threshold for a temperature (wiring, sensor, etc.) problem. It reached 206 and the fan turned on! I let it continue to run, thinking that if it keeps running the pistion rings might get warm enough to break in....HOWEVER a couple minutes later it died and would not restart, same as the first and second time. Crank no start, backfire sounds like it is trying through the intake?
I pulled the tmap sensor out of curiosity if it would try to start again like before, it did not start or turn over differently. Fuel pressure was still at 58psi. I then pulled injectors, checked for a leaking injector while it was hot, it was fine.
I had to go to work, so i left the house... and immediately thought "shit" i should have checked the plugs! Is this all over oil fouled plugs! am i chasing my tail because the plugs will run long enough to get fouled out by oil and then the motor dies? or am i reaching a temperature where a sensor starts to fail and sends incorrect timing information to the ECM?
I am VERY close to being done, but i figured the geniuses (Jungleman, or any of the other regulars ) could chime in and tell me im an idiot and to look somewhere specific.
8,000 (ish) miles
