Cheapest place to mail order tires
2965 Views 14 Replies 9 Participants Last post by  fdnyfish
Can anyone tell me a sponsor, or cheapest place to get tires
1 - 15 of 15 Posts
First off I know there are several good sponsor on here with good deals and would recommend them first but I had good luck with Rocky Mountain ATV.
I like Rocky Mountain ATV as well. There are some good sponsor here as well.
Matt Bell at ATV Outfitters.
Have you checked the local tire shops?
Motoxmall.com I've ordered from them. Good prices and prompt and free shipping, BUT some of the sponsors here are the guys that answer questions and help solve issues regularly so I would definitely consider them as well.
28" looking to stay with stock rims. Have a 2.5" lift
Haven't checked sponsers, but had good experience with Rocky Mountain ATV! Free shipping and made it to my door step in 3 days
I have. 2.5 marshal lift. What tires do you guys recommend? Are 28's to big? That what I wanted .
28x9x12 for front
28x11x12 for rear
dont want to use any spacers or a-arms
You will get several different opinions on tires, but I will suggest the Moto MTC. It is a good all around tire that will perform well in most applications and maintain a smooth ride. I guess it just depends on your riding style and preference. I ran 28-10-15 MTC's on my '14 800 crew with a 2" lift and they only rubbed in full lock and off camber situations. I am now running another set of 28-10-14 MTC's on my 900xp and have no rubbing, so my guess would be, if you decide to go with a 28 (MTC) they will fit and if they rub it should be minimal..
You also got new rims?, I was looking to stay shock rims
The only reason I went with new wheels on my crew was because when I lifted it, the offset on the 12" steel wheel was causing the tie rod end to rub the inside of the rim on the front (so I had to remove the lift until I could afford wheels). I had the LE wheels on my 900 but just went ahead and got tires and wheels before I lifted because of that experience. But if you are already lifted and not rubbing, you should be fine with just tires.
SAMS Wholescale Club is where I ordered my Mongrels
Looking at the ITP Blackwater Evolution 28x10x12 all around. Good? Bad?
Any Pro's or Cons having 10" on all 4 tires?
1 - 15 of 15 Posts
