Figured it out, it was the main harnes, right next to the fuel tank the harnes has a bend, which would touch the skidplate, barley, one green wire out of the monster wad had worn thru down to one strand of copper all outhers were ok , it was wrapped in a cloth tape, which showed no sighns of wear. Soldered it n the rangers cel lights were gone, fired up like nothing was ever wrong. Very happy now, we been using it for 6 mo now with no issues. Now finding this wire brake meant stripping the harnes from the engine towards the front of the machine was a bit titious but was the only way to have found this wire.all these machines vibrate and this is a common problem you will see quite often jus finding the break is tough and takes a lot of patients. hope this helps some one.
