Christmas presents!!!!
5177 Views 26 Replies 16 Participants Last post by  catmanLE
Just got a coulple more things for the ranger from santa, treadliner laser fit floormats and pawlprotector ebrake, floormats are great and the ebrake works good however needed alot of adjustment from factory mine was way to tight, and they could design a little more user friendly toe or foot engaugement area, will have to come up with something there, all in all though a prety good christmas for the ranger!!!!
1 - 20 of 27 Posts
I got a wiper kit
i wanted doors. i got a coffee maker. :apathy:
What's her name ?:biggrin:
Reactions: 1
Vehicle Automotive tire Tractor Tire Soil
I got a lift kit and 28" Zillas on 14" M12 wheels a month ago and my wife said Merry Christmas then!
wife. :encouragement:
Got the madness started with a new '15 Ranger 570!
Sent from my XT1030 using Tapatalk
I got a trailer dolly. My wife hates my Ranger but I justified the dolly because I pulled my back moving my trailer by hand this year.
I would like some more info on the treadliner mats. I have looked at them online, they look to fit well.
How pliable are they?
How good is the traction between the mat and the floor, and the mat and your shoes?
Do they move around?
How thick are they?
Any additional comments are welcomed.
I got the 2015 Ranger 900 in Sunset Red should be ready for pick up sometime this week after all the installs are done
Reactions: 1
I got a duplicate plastic A-pillar grab handle just like on the passenger side. Going to install over New Years. Hopefully I can mount it in the exact same position as the passenger side.
I did it and it worked out fine. Just get it in the same spot so it doesn't interfere with a lock and ride windshield. Must have if you have a windshield I think.
Reactions: 1
I also added the driver side grab handle. Ditto on precision mounting so it doesn't interfere with the lock and ride windshield. Hopefully saves wear and tear on the steering wheel by not using it as a grab handle.
Reactions: 1
A new 570 Full Size i bought for my wife and myself... mainly myself lol. Just picked it up the monday before christmas.
Land vehicle Vehicle Tire All-terrain vehicle Motor vehicle
I got a DDP primary and secondary clutch, super excited to test it.
As the others have stated, be sure and mount it in the same position as the passenger side. If you have or plan on installing the polaris lock and ride tip out windshield, and the driver side handle is mounted any lower than the passenger side, the gas strut for the window will hit the handle and not close, and could crack. Also do not overtighten.
I have the lock and ride fixed glass windshield, so I don't have to worry about the tip out windshield. I am going to measure the crap out it to get it in the right position. Toxic, how would I know if I overtighten, will the plastic crack? It seems very durable.
Hopefully you also received the mounting hardware with the handle. I installed mine and was fairly simple, just use the correct size drill to drill into the frame before running the screw up and into it. I used the mounting hardware like a self tapping screw and it worked fine.
I wanted to add a Grab-Handle to the wifes side....what is the brand ? Can you take a close up pic of it ? And I got new 'under pants' for Christmas...better then coal...but not much...
Stainlessman, The grab handle is from Polaris. Its the same as the passenger side grab handle. My wife ordered it through the Polaris dealer. The rops grab handle part number is (5439299-070), and the two bolts part number is (7518555). I didn't want the Velcro one they offer in the accessory page.
PC 57, That looks good. Now hopefully I can duplicate your precision work.
1 - 20 of 27 Posts
