1 - 8 of 8 Posts
Every time I have pulled the clutch cover off to check and clean the area, I had a ton of dust. Now I know why. It appears the last time I blew a belt it caused damage to the top of the back cover where the air exits the clutch box into the engine
5439086 DUCT-CLUTCH,AIR INLET has a tear and deformation:Also not the top of the Inner Clutch box has been worn away. I am going to pull the clutches this week and attempt to weld it all back to useable condition. If that does not work I will have to buy a new inner clutch box and air duct. $$$$$$#!t.
<font color="#000000"><span style="font-family: &quot">Every time I have pulled the clutch cover off to check and clean the area, I had a ton of dust. Now I know why. It appears the last time I blew a belt it caused damage to the top of the back cover where the air exits the clutch box into the engine.</span></font><br>
<font color="#000000"><span style="font-family: &quot">5439086 DUCT-CLUTCH,AIR INLET has a tear and deformation:<br></span></font><img src="https://www.prcforum.com/forum/attachment.php?attachmentid=125415&stc=1" attachmentid="125415" alt="" id="vbattach_125415" class="previewthumb"><img src="https://www.prcforum.com/forum/attachment.php?attachmentid=125417&stc=1" attachmentid="125417" alt="" id="vbattach_125417" class="previewthumb"><br>
<img src="https://www.prcforum.com/forum/attachment.php?attachmentid=125413&stc=1" attachmentid="125413" alt="" id="vbattach_125413" class="previewthumb"><br>
<font color="#000000"><span style="font-family: &quot">Also not the top of the Inner Clutch box has been worn away. </span></font><br>
<font color="#000000"><span style="font-family: &quot">I am going to pull the clutches this week and attempt to weld it all back to useable condition. If that does not work I will have to buy a new inner clutch box and air duct. $$$$$$#!t.<br>
<br>
</span></font>
The pics came through
Discussion Starter #3 (Edited)
Plastic Repair
This was a plastic welding day. I found three places on the inner clutch cover to weld up and one was a fairly large triangular hole about 1.25 x 1.5 inches. Another was just a crack about 1 inch long. The third was the seal groove where a broken belt had taken out the inner part of the grove wall about 3 inches long. When we took the inner cover off, we discovered a seepage on the primary – I think my maintenance plan should cover that.
The other part today was the roof. I had a long crack on the rear of the passenger side about 2 inches to the left of the last screw. And an older crack from hitting a limb over a year ago.
All the welds had 1/32” stainless mesh imbedded into the plastic then filled and smoothed it over. I think it looks fairly good myself.
Thanks Ken for you facility and assistance.
Good news from the Stealer, my extended warantee will cover most of the repair minus the deductible. The labor alone will be intense, I hope they put everything back together with the correct torque values and in proper sequence. Just glad I don't have to participate I know less than nothing about pulling apart an engine.
Discussion Starter #7
The service writer (Tech) told me all I would pay was the deductible. Last year when my rear and front windshields were broken that is all I paid, $50.00 deductible.
Discussion Starter #8 (Edited)
Well we got the wrong part so I won't have a Ranger for the month. I have a picture of the weeping primary. Weeping inner clutch seal and cover.jpg They discovered the rear half shafts are weeping and that will be a seperate warantee cclaim. Eventually when the web site lets me I have six pictues to upload:
Outter box seal groove.jpg Exhaust vent outside.jpg Inside box cover.jpg Clutch box exhaust duct.jpg
The welds could have been smoother but it was the first time I worked with my new plastic welder. Each weld is held together with 1/32" stainless mess screen inbedded in the plastic. Then I added more plastic on top of it. IF and when I take the inner cover off again I will try to smoot it out some with a heat gun and the welder.
1 - 8 of 8 Posts
