1 - 2 of 2 Posts
2008 ranger 500, new piston, rings and jug, new injector, new fuel pump. Fuel pressure is 42-43 psi, will run on either but not on gas. Motor is in time, new gas, cleaned the fuel tank completely. When you crank the motor it will hit twice then it just spins over. Changed the spark plug as well. Installed the new sensor on top of what would be the carb and the lil grommet. Need help
· Administrator
State, nine times out of ten when it will run on ether ..........it is still a fuel delivery/ pressure issue . If it is NOT an OEM injector, I would sure be suspicious of it. There are more bogus Polaris injectors for sale these days then there were Biden voters..
1 - 2 of 2 Posts
