I want to install a dashmount 3-way switch to control my winch when i am using the plow...rather than messing with the remote control. I still want to be able to use the remote when winching...
Can anyone help me with the wiring?
Thanks.
Go to Superwinch's website and download the install instructions for a Tera35 or Tera45 it has it in there to be able to use both.
I would look at the shifter mounted winch controller, and if you use it, be sure to wire in a disconnect somewhere, so the buttons on the controller do not get inadvertently pushed when you do not want it to. This would make your plowing easier, as opposed to the dash mounted switch.
Polaris accessory part # 2879227 $39.99
Thank you skipper. About to do this install this weekend. Sometimes I just need to tighten up the winch and do not want to always get the remote out for that.
