1 - 20 of 25 Posts
Lurking on this form for a while and came across clschultz79 post on his door build.
I am also using 3/4” 14 gauge sq tubing. I will be skinning them with HDPE plastic sheeting.
I am also using bullet-style weld-on hinges and tractor-style door latches. Please excuse the messy shop.
Automotive tire Road surface Asphalt Gas Wood
Vehicle Car Motor vehicle Automotive lighting Hood
Automotive tire Motor vehicle Automotive design Bumper Fender
Tire Wheel Automotive tire Hood Motor vehicle
Looks good so far!
Slot your holes in the hdpe. Or make them larger and use fender washers. It does expand and move with temperature changes.
Nice job 👏
That would be a hard no. The stuff is like Teflon and nothing sticks to it.
Does glue stick to polyethylene?
Polyethylene has a non-stick surface, which means most types of glue will not form a bond with the plastic. However, there are other ways of forming bonds on Polyethylene surfaces. The two best options for bonding Polyethylene are: Solvent Welding, Ultrasonic Welding or Infrared Welding.
Discussion Starter · #8 ·
RJ Thank you for the info. I will use screws to attach the HDPE sheeting to the box tubing. You saved me the frustration of finding out it would not work the hard way!!
2011 Ranger 800 6xCentipede
Looking great JAz, nice work! Looking forward to watching your progress.
Discussion Starter · #14 ·
Ranger door build cost
60 feet ¾ x ¾ box tubing $85.00
Bullet Hinges $55.00
HDPE Sheets $160.28
Door Handle Set $26.00
D-Shape Door Seals $54.00
300 Sheet Metal Screws $34.00
LEXAN windows $80.00
Paint $10.00
Grand Total $449.00
The first gen must be an exception to that. I've locked myself out of my 1988 extended cab (manual locks) twice and the first time the kid they sent out had to get his boss out there to pop it and that still took over an hour and the second time they bent my door so badly from prying it that I sued them for a new one.
This stuff here works good for door seal. It's expandable and comforms to different thickness gaps. They make it in different sizes.
Reactions: joemweb
Discussion Starter · #20 ·
Thanks for the info, I bought KX Automotive Universal D-Shape Door Seal 0.47" Height X 0.55" Width Weather Stripping EPDM Rubber Seal Strip Self Adhesive Car Truck Door if this does not work I will get what you recommend.
1 - 20 of 25 Posts
