Door Tether Improvement
1 reading
8.1K views 10 replies 5 participants last post by  Nosticks
I've got a 2015 Ranger 570 FS with the Polaris Lock N Ride doors. The doors are equipped with a rubber tether to keep them from swinging too far backwards when they are opened, and it works well on flat ground when the Ranger is level. The problem is that I live on some steep ground and it seems I'm always stopping on a slope somewhere with the front end facing uphill. When I open the door if I let it go, which is a habit I've picked up from driving cars and trucks, the door swings all the way back and hits the bed stretching the rubber tether to the max. So far no damage has occurred to either the bed or doors, however I'd like to be proactive and prevent such an occurrence. Anyone else found this to be a problem and found a solution? I'm looking for ideas beyond what I already have in mind (I'm not mentioning what that might be to prevent my ideas from influencing someone else's free thought) and if someone has come up with a good solution there's no sense in reinventing the wheel.
Thanks!
Steve
#5 ·
Thanks, I look forward to the pic.
#4 ·
Tethers on doors? I have full Polaris enclosure and have no tethers. Dealer installed the enclosure. I have the same problem with the suicide doors, particularly when it's windy. It's easy for them to get away from you. I'll have to think about what would work without getting in the way every time I get in and out.
#7 ·
Your doors should have come equipped with a rubber tether similar in appearance to the rubber tie down bungees you see people use to tie down tarps and so forth. The are attached to the back of the cab and to the door at the top. Your dealer left them off, unless Polaris has cut expenses and no longer includes them.
#6 ·
The older door sets used webbing material, and I believe they were adjustable.
Although it probably hasn't hurt anything, the constant pulling of the door seal by the limiting strap, will eventually take its toll on the door seal.
I would design something that did not contact the seal, but this will also decrease how far you can open the door.
#9 ·
Thanks, I figured from your posts that I should have tethers. Live and learn. My guess is they left them off. I don't think they deal with door here very much as evidenced by the poor fit on their install. I'm still adjusting the fit.
