My 2014 RZR UTV has electrical problems. When I turn the key on it just goes it’s just blank the batteries good I even put a charger on it but it will not even turn over, do you have any idea what is causing this problem thank you so much
Hi Drake, WELCOME TO PRC !.......... wait for it........................LOL. how do you know the battery is good ? The battery fairy said so ? A battery can have a bunch volts but NO AMPS and if you have no AMPS, that starter is not going to move. You could have a bad ignition switch or a bad ground or a bad solenoid, but I am betting on a shot out battery.. How old is that black brick anyway ?
As Jungleman said, look at the simple stuff 1st!
Battery terminal corrosion,bad cables,ETC
5 years on a rec. battery is waiting for replacement.
Welcome to PRC......Try a little test.....Turn the key on......Turn the lights on.......Watch and see how fast they go dim......If only a few minutes the battery is toast . :cool:
Check your cables after going on the beach and the salt water gets on mine they fail and i have to clean them for anything to work
