okay I have a 2014 xp900 I use to hunt I've noticed lately that its spinning over a little longer than normal before it starts at which point it runs great. and every once in a while it spins over for quite a while before it starts which has only been a couple times. what could be causing this?
Could be lower than normal compression from dust inhalation or the need of a valve clearance adjustment.
Also I'd check for leaks around the intake boots by spraying carb cleaner where the boots bolt to the head. If the engine rpm changes when spraying then the boots are leaking.
