1 - 9 of 9 Posts
Just got a 2013 900 XP LE. It is supposed to have EPS. When I drive it, it does not seem to have it. How can I tell if it has EPS? Sorry, still a rookie with this machine.
Are there two trouble lights lit up on the instrument panel? If so, then the EPS is disable. Run it up above about 3,400 RPM and see if the lights go away. Then the EPS will work. There is a recall on this problem.
There are no trouble lights on. I definately cannot turn the wheel with one finger.
This is a 2013 900 XP LE. Do all LE's have EPS?
Is there something I can look at in the engine compartment to see if it has EPS?
If you look up,under the dash by the steering wheel you should see a silver box inline with the steering shaft. If you only see a shaft and no box ( power steering pump) then you don't have it. However as mentioned above I bet you are part of the recall. Good luck!
1 - 9 of 9 Posts
