got this error code cant fide out what it means help me please
ronaldgacott · Registered Joined 12 d ago · 1 Posts Discussion Starter · #1 · 12 d ago Only show this user got this error code cant fide out what it means help me please
BPS · Registered Joined May 22, 2018 · 1,892 Posts #2 · 12 d ago Only show this user Voltage above normal range. With the engine running check the voltage at the battery with a volt meter. If it's 15VDC or higher you most likely have a faulty voltage regulator.
