Have the code 520228 12 showing. EPS light is on. Don’t believe the EPS is working. Any suggestions of what the problem could be and a fix?
I’ve seen that posted a few times. Drive in low range at higher Rpm’s. I haven’t tried it for 5 minutes tho. I will try that today.
Trit,
The consensus is, it is probably a low voltage problem. Either a battery problem or a possibly a a bad wire (somewhere). It wouldn't hurt to have the battery load tested to rule it out. You have made no mention of an attempt to repair so I would clear the code and after load testing and charging the battery .
