1 - 9 of 9 Posts
I have a 2" spacer lift from high lifter and after installing it I noticed the rear springs to be sagging quite bad. I had to turn the rear all the way up to make it some what level. Can I still run the spacer lift with the ev springs and still be ok with the factory axles. I have found some info on it but not a concrete answer.
I already have the lift, was think if anything I would just put the rear ex springs on it to get it back level. And does anyone know if they make a 1/2 wheel spacer. When I put the terminators on, it makes contact with the tie rid end on the passenger side
Land vehicle Vehicle Car Automotive tire Tire
I installed 2" lift with EV springs and the back of my machine is way higher than the front. i gained about 5 1/2 inches out back and 3 1/2 inches in front. right now my rear axles are at 34 degrees and are maxed out. fronts seem ok. going to order some Cobra axles soon. The pics are not that great..
· Vendor
Nice ol ford behind the ranger.
It belongs to a buddy at work. Here's a video of it, just a short trip after work one morning. My favorite part was taking the Ranger through the same hole that he had some trouble with. LOL!
1 - 9 of 9 Posts
