Just thought I would show my factory looking installed switches. I had to buy the fan switch that was just ON/OFF just to steal the face of it to put on the ON/OFF/ON switch. I used waterproof hella 40 amp relays to keep all the voltages separate. These are all OTRATTW switches
So heres how the fan works, in the down position the bottom light is on and the fan works normally in auto,(light stays on to indicate its in auto), in the middle position the fan is off and does not work at all "I like this for entering water or deep mud to keep from burning the fan up", In the up position the bigger light with the fan on it is on and the fan runs constant as long as the key switch is on!
The winch rocker lights up the upper light when pressed, and the lower light when pressed. its momentary.
The dome light lights up the top with light pointing down when its turned on, the lower light comes on whenever the key is turned on. Kind of like a dash light.
If anyone has questions please ask. Its alot of wiring but i can explain it hopefully. also if anyone has any electrical questions just ask, I install and program Honeywell, Johnson controls, and facility explorer ddc controls for a living.
