Hope you don't mind as I didn't see it over here.
Originally posted by Fire Guy:
OK I have a fix for the 07 XP reverse activated backup light!!!!!!!!!!
Go to NAPA and pickup a resistor RELAY part # AR204 it has 5 male slip pins for the connections. Here's how to wire it:
#85 plug in the Purple (reverse ground) wire under the bed
#86 run a jumper to the Red positive wire also under the bed and plug into #86
#87 Ground this to your frame (this will be the ground for your lights when the switch is activated
#30 connect this to your ground wire leading to your lights
#87a nothing hooked to this one
The Relay has a nice mount built into the housing , just attach it to the frame near the wires (Purple & Red)
No more fault engines codes, all the electronics work and the best of all the Reverse lights work when you put it in Reverse.
Oh, by the way I tried 3 different attemps to contact Polaris to get some help on this and they never bothered to reply, hope someone from Polaris reads this, maybe they can take credit for the fix - sorry to be sarcastic about Polaris but I think it was pretty rude that they didn't even bother to respond
