Finally got the first ride on the RZR. I am very happy with the performance. The only issue I had was the seatbelt. I forded a creek where the seatbelt ratchet was submerged and then it would not retract. I was able to roll it up manually and then it was locked in place. When I got home, I unbolted it, sprayed with WD-40, to no avail. So, I pried the plastic covers off of the ratchet. That was not a good idea since the spring went flying. Long story short, I was able to put it back together so that I can adjust it manually and set it to my size. I will not retract or extend without manually releasing it. I do not want to wait on parts or repair under warranty. I am thinking of purchasing a four point harness for it, since I don't want another one ride only seatbelt. I hope no one else has this problem. If your belt does not retract and is locked, do not manually push it in, because then it will not unroll, and is unusable.
