<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by Curmudgeon
For comparisons sake, most car engines run about 205, but that's in order to maximize the mileage. I put 180 thermostats on most of my personal cars to save the wear and tear of the heat. Hope this helps.
Might wanna watch that thermostat swapping, especially on recent cars. The computer is programmed to bring the temp up to a certain level, and since it never reaches this level it can continue to overcompensate in an effort to reach it.
There's nothing wrong with 200F coolant. Pure water doesn't boil till 212, and just a simple pressure cap will raise it (the boiling point) a good bit above 212 anyway. After you factor in coolant additives, the boiling point's so high as to not be an issue.
Modern oil can withstand the internal engine temperatures, so you're not helping it with the 180 thermostat. It simply makes fuel economy worse.
And if it actually lasts, say, 20k miles longer, but drops the gas mileage by 1 mpg, are you any better off?
Take a typical car's life of 200k miles. Figure 15 mpg, but drop that to 14 due to the cooler temp. That adds about 1000 gallons of gas to the consumed total, and about $3000 to the cost of owning the car. This doesn't count the extra $ in fuel filters, gas station fillups, etc.
