2016 900xp has finally had the front diff. Give up. First failure mode was not going into 4wheel drive when I was going forward in a creek. Put it in reverse and it locked in and I was able to back up. It’s worked intermittently ever since.
So now I am just getting ready to dive in and rebuild it. Any suggestions on what rebuild kits to use or avoid? I am running 31” tires on it.
Thanks.
I would recommend shooting me a message.
Reactions: Stroke250
Toxic, is it possible to openly discuss problems and solutions for front gearboxes and transaxles? The constant requests for PMs is only helping two people, you and the OP.
No answer to the question and I am needing answers also. My axles wobble all over the place and pop occasionally. New diff or rebuild this one?
They are pretty easy to rebuild. New seals and axle cups is usually all you need. Unfortunately the cups are about 370 dollars. Go ahead and throw in new axles and u joints in propshaft.
Sent from my SM-G991U using Tapatalk
