How much negative camber is acceptable in a 2013 Ranger 900 XP EPS?
My front tires lean in. I run mostly pavement and gravel, and I'm showing significant wear on inside of my stock pxt tires. I only have a 1000 miles on the ranger. The drivers side is 3.3 degrees and passenger is 2.3 degrees. Is this normal? It drives down the road straight with no vibration.
About the only way to fix it is aftermarket A arms. "They" say the there is so much negative camber to help with off road handling. I bout some Super ATV A arms that have adjustable camber and mine are set to about 1 degree. Much less than stock, although I didnt measure it, must have been around 4 degrees.
That's what I was kinda thinking, thanks Bernie.
