1 - 7 of 7 Posts
Are there any front mounted rough cut mowers available for Rangers? I recently purchased my first polaris Ranger 570 full size a couple weeks ago and I want to be able to use it for cutting trails and maintain food plots. I know they have pull behind ones but I'm more interested in one for the front.
Sent from my VS985 4G using Tapatalk
I would also look at adding a fan reverser, to help keep the radiator clean. With the front mount mower, you and the ranger are going to be taking on a lot of dust and debris.
You can get a 3 point hitch that mounts in the front or rear receiver. Get a standard engine powered trail mower and fab up some 3 point mounts, or you can probably find one that's already set up. Then you can use the mower on front or rear. If you're maintaining food plots the 3 point hitch will have many other uses (plowing/planting).
1 - 7 of 7 Posts
