21 - 26 of 26 Posts
Same general scope of the other code. Check and do what I told you first .
Code............All Wheel Drive Control Driver Circuit Short
Wifi, check the fuses and then see if the 'turf mode driver" in the back with the harness going to the turf mode solenoid is damaged OR if the driver box is very hot.
When I see that code it's usually a disconnected or broken wire on the front gearbox harness.
I was going there eventually but wanted Witzi to start in the back . Many of those driver boxes in the rear have been known to fry throwing a code.
Well gee Wit, switch them back and find out....
Reactions: RJ
21 - 26 of 26 Posts
